Where should my next fan go?
15 Mar 2010
The roof can accommodate a NF-P14 and the bottom front would accommodate only a NF-P12. A DirectCU II 670 will be arriving shortly.
It would certainly be mine but the NF-P14 I just bought doesn't fit there and I kind of reluctant to use a NF-P12
Exhaust out the top IMO. The Direct CU II will be chucking out hot air into your case, and the only exhaust you have currently is via your CPU cooling.
How about swapping the fans around on the Corsair radiator as intake from the outside (I always thought this was the way to get best performance using cooler air), and using a new fan at the top as the exhaust?
testing out there on this shows only 1 c difference normally between intake and exhaust. My h100 mounted in the roof seems to perform about the same but the GPU#s below are about 2C cooler acting as an exhaust. I am not calling this conclusive or even scientific as I fitted a direction mount to the side fan at the same time but I've not seen any detriment.
Maybe try opening up all PCI slots with top and front intakes pushing heat from GPU out the back?? Would supply CLC and mobo with cool air as well.
