New Build. Advice Needed on spec
Suspended
2 Dec 2004
Under The Desk, Wales
I want to build a small PC that is fast and can handle Photoshop easily.
I already have an SSD so would need everything else.
Read that the i3 2020 is a good CPU? Onboard GPU will be fine as i dont really game these days on the pc.
Also, Micro ATX is biggest i need to go. Was contemplating MiniITX but not sure now. Budget is max £350. 8gig ram would be ideal.
What CPU / Mobo would you recommend? Thanks
might seem over spec'd for a bit of photo shop but its in budget :).
could reduce the cost to £200 swapping the cpu for the i3-2120 and motherboard for an h61 m-atx board.
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £181.99
1 x Gigabyte Z77M-D3H Intel Z77 (Socket 1155) DDR3 Micro ATX Motherboard £86.99
1 x Kingston HyperX RED Limited Edition 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3B1RK2/8GX) £43.99
Total : £324.37 (includes shipping : £9.50).
sometime soon the Ivybridge i3's are coming out and the flagship one has HD 4000 Graphics, which can actually handle some games pretty well. So getting one of them will open up many possibilities.
This set up would go well with an ivy i3.
YOUR BASKET
1 x MSI H77MA-G43 Intel H77 (Socket 1155) DDR3 Micro-ATX Motherboard £74.98
Total : £129.47 (includes shipping : £8.75).
I heard rumors they are either out today or some this week.
Sorry I should have been more specific. I was looking at their range of laptops and PC's. And some of the laptops but none of the PC's had the Ivy i3's in the specification.
makes a bit more sense :D, with the ivybridge's being less power hungry and the better onboard graphics for lappies.
This looks good. So an i3 2020 would be fine on this board?
This ok guys:
Just got to find a cheap case if all above ok. Got an SSD hard drive.
Is the above motherboard a bit of overkill? Does it matter if an SSD is not connected to the faster sata connector? Would i be better off buying a cheaper mobo? If so, which one?
You could try this one - http://www.overclockers.co.uk/showproduct.php?prodid=MB-386-GI&groupid=701&catid=5&subcat=1965
• Still mATX
• Has USB3.0
• Has SATAIII (provided via a third party chip)
• DVI, VGA outputs
• Zero overcloking potential if you decided to get a "K" CPU for example.
