** LANDED TODAY - THERMALRIGHT **
Damn it! Silver arrow is in!! ordered a phanteks at 0300am when i couldnt sleep lol. Ah well, phanteks is just as good, if not better
Silver Arrow:
contentteller.php
Silver Arrow SBE:
Saying that, the manufacturer code on the OCUK page doesn't help matters.
Are you going to stock
Thermalright Silver Arrow SB-E in the near future?
As Helios said, ocuk description clearly says SB-E in the link i posted, il put crash mats down incase you fall of ya high horse :p LoL
Hi Guys
apologies for the error in the listing.
I can confirm that it is the SB-E model
Thermalright Silver Arrow SB-E CPU Cooler (Socket LGA 2011/1366/LGA1155/LGA1156/LGA775/AM2/AM3/FM1) @ £69.98 inc VAT
8 X 6mm sintered heat-pipes effectively takes away excessive heat from the CPU when overclocked, Nickel Plated heat-pipes, slower Oxidation and deterioration of the heat-pipes, provides longer period of Thermal conductivity.
Double fin design , each side with 154mm*120mm heat dissipation area, can be used with 14 or 15 cm fan ( fan clips included).
Special Arrow fin design, which allows cool air to pass through and take heat away rapidly, effectively provide cooling for the cpu.
Support Multiple-Platforms. Can be used on Socket 2011/1366/1155/1156/775 Platform, and AM2/AM2+/AM3/AM3+/FM1 Sockets.
Including TY-150&TY-141 Ultra low noise PWM fans and PWM Y-Cable. With the compatibility of up to 3 fans maximum.
• Cooler Dimension: Length 155mm x Width 105mm x Height 165mm (without fans) 170mm x Width 130mm x 170mm (with both TY-141 and TY-150 fan installed)
• Cooler weight: 1124g (including two Fan, without mounting brackets)
• Heat-pipe: 6mm Sintered Heat-pipe*8 units
• Cooler Base Material: C1100 Pure Copper with Nickel Plating.
• TY-150 Length 170mm x Width 26.5mm x Height 150mm
• TY-150 Fan Speed: 500~1100 RPM (PWM)
• TY-150 noise level: 17~21dBA
• Fan Airflow: 38~84CFM
• TY-141 Length 170mm x Width 26.5mm x Height 150mm
• TY-141 Fan Speed: 900~1300 RPM (PWM)
• TY-141 Fan noise level: 21~25dBA
• Fan Airflow: 28-74CFM
Only £69.98 inc VAT.
ORDER NOW
got one out to confirm:
@rjkoneill
Thank you for the clarification.
Any idea about when / if TY-143 fans and Silver Arrow SB-E Extreme will be stocked?
My DH14 is singing, “I’m not such an ugly duckling…”
AsRock Z68 Ex4 G3, [email protected], Ballistic Tracers 16GB,
5850 1GB(CFX), CM90 II Advanced, Crucial M4 256GB, 4 HDDs,
NH-D14, XFX 850W BE, Xonar Essence STX, BlackGold HD DVB.
