- 27 Oct 2005
How maaany T10's!?!
(Yes i'm a pillock!!). So much more fun now.I think some people get to much higher tier without realising there is arty mode.
Other tips; hold right mouse button to lock your turret when looking around. You can use it while turning too; not sure if it saves some shrinkage.
X is handbreak.
X is handbreak.
That arty tip is news to me as well. Will take a look when I play later tonight. Tank companies anyone?![]()
i should be on about half 7 and will try and get a company going if we have enough![]()
) to get the motherboard back to OcUK for RMA tomorrow, however I should be on 9:30ish with my laptop for some games...Getting really fed up with being the only t4 tank in t6-t9 tank battles.
are you in one of the tier 4 lights that are classed as scouts ?
Isn't that any T4 light tank, regardless of how **** it is? It was so depressing playing the A-20 or Pz38nA after the T-50 or Leopard. The actual scout tanks are better in every conceivable way. The rest of them can't even scout properly.
Funnily enough I'm currently in the Pz38na trying to get the xp for the next tier which is a medium. I had 5 games full of t6-9 tanks and it's hard to scout as its not that quick or manoeuvrable. Then I take 1 hit and I'm out. Just have to put up with it and grind to the t5.
find a bush near where you think the front line will be and hide just behind it, don't move or fire after you get there, the enemy shouldn't see you until they are around 50m away from you.
hopefully your team will shoot anything you spot before it gets close enough to spot you and you will get xp to the equivalent of half of what the damage your team mates are doing.
