Just bought the H80 from OCUk, hoping nit will fit on my P5Q Premium (will need to rotate the cooler 90º otherwise it rests on the capacitors).
Because people still pay stupid money for the Q9550 on the bay? The money he get would probably be (close) enough to get a i3 2120. And rather than spending £80 on a CPU cooler, he can get a Z77 motherboard instead. As for memory of he got DDR3 he can reused them, if not he can selling the DDR2, and get some DDR3 (DDR3 memory are dirt cheap to the point that the money he get for selling hi 4GB of DDR2 could be enough for getting 8GB of DDR3 new lol)the problem there is who would buy the q9550 setup if its so cheap to buy the replacement.
Actually the Q9550 would already net him around £80+, regardless of he might or might not be able to sell his motherboard. Despite the i3 2120 won't overclock, on stock clock would be as fast as Core2Quad at around 3.8-4.0GHz in games that use 4 or more cores, and FASTER in games that use less than 4 cores. The stock cooler for the i3 2120 is more than enough, as the i3 2120 has lower power consumption and generate much less heat. So it doesn't really cost much for an upgrade, and open up a future upgrade path. I just don't see the worth of spending £80 on a CPU cooler for overclocking the Q9550 to get worse gaming gaming performance than a i3 2120.Selling a 775 mobo and cpu will probably net him £80 ish. A board and new equivalent CPU like an i5 would easily cost £200 second hand. Cost is £120 to upgrade but he would still need a decent CPU cooler. His current one may not support new sockets. Yeah, it is close, and I have been down that road but where do you draw the line. Nothing really wrong with a decent 775 setup still, plenty of life left.![]()
The Core2Quad at 4GHz would probably be a bit faster than the SB i3 for heavy-duty stuffs like encoding, but for most general usage and gaming, the i3 2120 would be faster. But the IB i3 would probably be faster than the Core2Quad 4.0GHz at everything (hopefully).Is the i3 2120 better in all aspects than a core2quad at 4ghz? Not gaming, I mean apps based performance. I was unaware they are worth that much.
Considering if the OP is gonna blow £80 for the sake of overlocking the Q9550, then going i3 and save the money from the cooler is actually more production overall.Going to a i3 21xx is bad advice - stock for stock theres barely anything in it and you just spend money and put effort into reinstalling, etc. to see very marginal gains at best in the real world you probably won't actually notice the difference (even in games its generally ~5% difference) - if your going to change out the motherboard, RAM and CPU do it proper and go for a generation leap in performance.
Overclocking a Q9550 seems to depend more on the quality of the motherboard more than anything else - I've been using a Coolermaster V8 with mine (fan modded) and I've tried various boards from the current nForce which is pretty poor and P35, 45, etc. boards with wildly different max overclocking results without any change to the cooler (I've been all the way upto 4.6gig with mine without any significant cooling issues using a fairly middle of the road air cooler).
Q9550s are going for well over 100 quid in many places.
On games like BF true the performance difference between the i3 2120 wouldn't be much as the game would take advantage of using all four cores, but games that use less than 4 cores it will make the Q9550 cry WILL have noticably worse performance than the i3 2120.
But yea I agree i3 2120 is now indeed bad advise, considering a month has passed, and IvyBridge i3 is now around the corner.
Hmm..really? I have a q9450 (ok not as good) and last time I checked they were only worth about £45.
