Coolermaster GX Lite 500w PSU *** Best UK price ****
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
This SKU is aimed at low to mid range PC builds with a great set of features including a range of safety measurements and a 80 Plus efficiency rating :)
Cooler Master GX Lite 500W '80 Plus' Power Supply @ £35.99 inc VAT
GX-Lite power supply is the light version from the original GX series, it specifically targeted at systems in the mid to high range, yet reasonably priced, providing users with unsurpassed cost per performance. Features single highly 12 V rail, proficiently delivering power all the way up to 86%, also supports most demanding components including the processor, drives and cooling fans. The GX-Lite Series will keep the power in your hands.
- Type: Intel ATX 12V V2.3
- Input Frequency Range: 47Hz ~ 53Hz
- Power Good Signal: 100 ~ 500ms
- Hold Up Time: >17ms
- Efficiency: 86% Typically
- Protection: OVP / SCP / OPP
- Operation Temperature: 0 ~ 40?(Nominal Input Voltage)
- Dimension (W / H / D): 150 x 140 x 86 mm (5.9 x 5.5 x 3.4 inch)
- Input Voltage: 180-264V (Auto Range)
- Input Current: 5A
- Input Frequency Range: 47Hz-53Hz
- PFC: Active PFC (>0.9)
- Power Good Signal: 100-500ms
- Hold Up Time: 17ms
- MTBF: 100,000 Hours
- Protection: OVP / OPP / SCP
- Output Capacity: 500W
- Operation Temperature: 0-40?(Nominal Input Voltage)
- Regulatory: TUV / GOST / CE / C-Tick / CCC / KC
- Fan: 120mm
- Connectors: M / B 24 pins x 1 / CPU 4 + 4 pins x 1 / PCI-e 6+2 pins x 2 / SATA x 6 / Peripheral 4 pins x 2 / Floppy 4 pins x 1
Only £35.99 inc VAT.
ORDER NOW
Interestingly Cooler Master don't seem to have its amp ratings on their product page.....
What are its rails and amps ace?
I certainly wouldn't use it to power any of my systems but at least its not the usual case of 500A on the 3.3v rail , 1A on the 12v rail!
:D:D:D
I often see this on cheap psus adevrtised with high wattage then when you look at the spec, what you said is true (but not that exagerated), so it is useless.
Description says 80+ efficiency, but I guess it's not "certified" ???
Nothing to see here. Move along. Much better psus cost little more than this. Even coolermaster sanction much better psus for a few pounds more.
