I can't explain it then. You geolocate to the UK. Some IPs are known to be located in other countries but geolocate elsewhere, that's not what's happening with you.
Indeed, there's around 4 lists commonly used. However if he shows up as UK with a proper location on 3 out of 4 then I'd put a considerable amount of money on him showing up on the 4th. The lists are usually right, it's only for funny IPs - you can buy French servers which are located in France but geolocate to Poland for example - that it's wrong. I've never seen them be wrong for ISPs.Only on that list, the list the BBC use may well not be the same.
That's essentially what he's done. He's connecting from Virgin, which means there's no malware proxying his connection - or at least it's only doing it sometimes.If he thinks he has malware proxying his connection why not try some whatismyip type sites?
y was permabanned suspended?
He posted an image with a swearword in it in another thread. You won't miss him.
