http://www.overclockers.co.uk/showproduct.php?prodid=GX-030-KF&groupid=701&catid=1914&subcat=2255 - Card
http://www.lg.com/uk/monitors/lg-E2281VR-led-monitor - Monitors
Hi, i recently bought my new graphics card "before i was using a AMD 6950".
My OS is windows 7 proffesional N 64 Bit.
My Machine is updated and is using the latest Nivida Driver.
The problem is this, I connect my 3 screens with hdmi - mini hdmi cables to the 3 mini hdmi ports but only 2 screens turn on.
The card is detecting the third screen as in the windows and nivida panel i can change settings for it but the screen just says "Check signal cable" and in the nivida pannel it says "This display does not support HDCP" now considering this screens are all the same and well looked after i dont know what to do.
The Card is working fine "All ports are working".
The Screen works *Though when i take the same screen and switch it for a pre-working screens cable/power cable it doesnt work -_^"
and all the cables work.
Any ideas where i am going wrong ?
