The new 18W ultra pump is here.
looking at the stats, you cannot argue with the capabilities from the new offering from Laing.
This latest revision offers 900L/h which is 300L/h more than the last 18W DDC ultra and approaching the 1200L/h maximum of a D5 in something half the size!
Couple this with HUGE head pressure and this pump is looking set to be the best option for watercooling enthusiasts.
Laing 18W DDC-Pump 12V DDC 3.25 - ULTRA PERFROMANCE - 900lph @ £68.99 inc VAT
This pump is the first pump worldwide which is used in mass-produced water cooled workstations and is ideal for the water cooling of processors and electronic components. Due to its compact size and its power it can be used for many applications.
This DC pump is an electronically commuted ball motor pump with an estimated lifespan of more than 50.000hrs at 12V. The only moving part on the pump is the spherically shaped Rotor unit which is sitting on an ultra-hard, wear-resistant ceramics bearing ball.
A conventional shaft with bearings and seals is not used or needed. The spherical bearing of the rotor unit on the ceramics bearing ball has many advantages: The development of bearing clearance is technically impossible which results in the impossibility of noise level increase over the lifespan of the pump. The bearing is self-adjusting, making the pump consistently quiet in operation over the full lifespan. The pump is directly lubricated by the coolant (wet-running pump). Therefore no maintenance is required.
As the rotor is magnetically held in place even small dirt particles pose no problem for the mechanism, a blocking of the pump is not possible under normal operating conditions. Even after a long period of standstill reliable operation is ensured. The permanent magnetic rotor unit is driven frictionless by a magnetic field which is produced by the surrounding stator.
The stator is completely built around the rotor, therefore the pump is with its 38mm only slightly higher than the stator unit. It therefore fits a in almost any PC case, may it be Super tower or Barebone. A separate magnetic shielding is usually not required. The ball motor principle allows powerful yet power-saving operation. The pump can be regulated by power variations of the DC operating voltage over a wide range. All parts in touch with the coolant are completely corrosion free.
Technical details:
Dimensions (WxDxH): 90x62x38mm
Motor: Electronically commuted ball bearing motor
Nominal voltage: 12V DC
Nominal power consumption: 18W
Certified voltage: 6 to 13,2
Pressure head at 12V: 5,7m
Maximum flow rate: >900l/h
Coolant: Water /Glycol/Glycol mixtures
Maximum system temperature: 60°C
Materials in contact with the coolant: Stainless steel 1.4571, PPS-GF40, EPDM O-Rings, Aluminium oxide, hard coal
Fittings: 2x 3/8" barbed fittings (For hoses with an outer diameter of 10mm and 8mm inner diameter)
Extent of delivery:
Laing DDC pump 12V DDC 3.25 18W
Speed signal: With 3-Pin Molex connector as speed signal output (for Mianboard or fan controller connection)
Note: This pump is the latest revision
Only £68.99 inc VAT.
ORDER NOW
Technical details:
Extent of delivery:
ORDER NOW
