- 18 Oct 2008
- UK
hi,
could someone advise me on cases please?
my current case is a resprayed HAF 932 which i got back in 2008 so ive had a lot of use out of it, but is now not so roomy inside.
ill be working on air only aside from a Corsair Hydro H100 4 fan push pull on the ceiling for the CPU.
basically ill be upgrading next year on the cpu/motherboard and need a case that will last for another long period say 4 years
what im looking for are :
**needs to have room for 4 Gpu with sufficient spacing on 4th gpu (3 gpus currently and its tight so need room to breath for 4)
**need 3 or 4 fan support in ceiling
**PSU can be partitioned if facility is there
**floor fans blowing up if available
**enough airflow for gpus**
ive looked around these what appear to tick some boxes
Cooler Master HAF X Gaming Tower Case 942 *not sure on roof for cpu radiator*
NZXT Switch 810 Big Tower Case - Black
Corsair Obsidian 800D (6GB/s) Full Tower Case - Black
BitFenix Shinobi XL Full Tower Gaming Windowed Case - Black
Xilence Interceptor Pro Full Tower Case - Black/Red (would the Corsair Hydro H100 tubing reach the cpu with this installed its seem too high from the ceiling to cpu anyone advise me on this? )
i know some say the corsair isnt for air cooling but wouldnt it be acceptabe with the cpu being cooled by the radiator in the roof?
by the way i dont need a fancy case as ive had my haf like a christmas tree since is was moded and i find it boring now so bland cases wont bother me. (im past all that now
**added** sorry i forgot price range i think corsair is my max for price so £250 is the budget
many thanks
HR
many thanks
HR
