Lowest UK Pricing - High end Wireless Logitech Mice!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Logitech Performance MX Mouse with Darkfield Technology (910-001121) @ £38.98 inc VAT
With the Logitech® Performance Mouse MX, you have the power to achieve. You can track precisely on more surfaces – even glass tables (4 mm minimum thickness) – thanks to Logitech Darkfield Laser Tracking. Your tiny Logitech Unifying receiver stays in your notebook. There's no need to unplug it when you move around, so there's less worry of it being broken or lost. You can recharge your mouse through your computer or a wall socket, even while you're using it, with flexible micro-USB charging. You'll fly through long documents with hyper-fast scrolling. And its sculpted, right-handed shape with integrated thumb controls puts everything under your command.
- Darkfield Laser Tracking Technology
- Tiny Logitech Unifying receiver
- Hyper fast scrolling
- Sculptered, right handed shape
- Includes Micro-USB charging cable
- 3 Year Warranty
Was £69.99 Inc. VAT
Only £38.98 inc VAT.
ORDER NOW
Logitech Anywhere MX Mouse with Darkfield Technology (910-000873) @ £24.98 inc VAT
The Logitech Anywhere Mouse MX works wherever you do. Thanks to Logitech Darkfield Laser Tracking, you'll get precise cursor control on virtually any surface, even glass tables (4 mm minimum thickness) where optical and standard laser mice fail. You can take it anywhere thanks to its compact size. The tiny Logitech Unifying receiver is small enough to leave in your notebook. Anywhere you go, you'll get things done more comfortably with its sculpted design. You get hyper-fast scrolling to fly through long documents and Web pages with a single spin of the scroll wheel. Plus thumb buttons let you go back and forth between Web pages with just a click.
- Darkfield Laser Technology
- Tracks virtually anywhere, even on glass tables
- Tiny Logitech Unifying receiver stays in your notebook
- Sculpted, compact design that's easy to take with you
- Hyper-fast scrolling
- 2x AA Batteries Included
- 3 Year Warranty
Was £49.99 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
ive got the top mouse and love it,amazing price as well guy's :)
How do you get on the the smooth scrolling in games? I have a cheapo wireless mouse with smooth scrolling and it's awful for gaming. It frequently moves accidentally and changes the weapon in using.
You can switch between normal and smooth scrolling.
Thanks for the darkfield offer :)
Been waiting to buy this mouse for ages.. perfect timing as my current MX mouse is being a bit ****!
cant fault the mouse,i play a lot of different games and never had a problem with it.
It's rechargeable as well and last's 2 week's with normal use,if you do find the battery is running low while your playing a game,you can plug the cable in and still use the mouse while it recharges :)
my last logitech mouse (mx revolution) came with a charging cradle and had to be put on it to charge the mouse,so with the cable on this one is a god send.
well worth the very low price.
Does anyone find the weight and size of the Performance MX an issue for gaming? Looking to transition from my MX510 to something with a better shape for comfort.
aww, i brought the mx 2 weeks ago from elsewhere cause no-one had it in stock t this rediculouse price :(
I have to admit though, its a comfy bit of kit
Ive got the top mouse and game with it. Really great mouse as others have mentioned. Use on the same dongle with a K750 keyboard and its perfectly fine for normal gaming.
Will the wireless adapter for the performance MX work with my Logitech K300 wireless keyboard?
No, sorry it won't. The k300 didnt come with a unifying receiver. The new k340 (which I have) is the updated model with unifying receiver.
The unifying receiver can add other unifying receiver capable peripherals but not the older type. I tried with an ordinary logitech wireless mouse just to test.
