You really need to get exact numbers to be able to run this, but my suspicion would be that there is going to be a significant installation cost which might well render this cash neutral or negative - I'd get this checked out before spending more time on the endeavour.
If you're looking at options to use an initial outlay to provide longer term savings, have you considered looking at a ground source heat pump for your heating needs?
