** Today Only ** 30/06/2012
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Samsung S27A750D 27" 120Hz 3D Widescreen Ultra Thin LED Monitor - Glossy Black @ £299.99 inc VAT
Samsung’s 750 and 950 series 3D desktop 3D monitors feature high refresh rate, incredibly thin bezel and stylish design. These monitors are able to analyze and render 2D content in real-time to 3D, supporting PC content, Blu-ray films and gaming consoles. The monitors feature a built-in glasses sync emitter, and they are packaged with a pair of 3D active shutter glasses.
Viewers will experience deep, rich colours and image clarity with Samsung’s new Ultra Clear Panel technology, which combines the vibrancy of a glossy display while maintaining the ease of viewing afforded by an anti-glare matte finish. The LED-backlit panel boasts 100% sRGB coverage to produce realistic colour reproduction.
Features:-
- 3D Active Glasses are included
- TRUE 120Hz
- 2D - 3D Conversion technology
- Screen Size: 27" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000000:1
- Brightness: 300cd/m²
- Response Time: 2ms (2D) / 2ms (3D)
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x HDMI, 1x DisplayPort
- Warranty: 3 Years On-Site
- **Zero Dead Pixel Guarantee** - If your Samsung S27A750D has dead pixel(s) you may return it for a replacement within 14 days of receipt.
Was £349.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Samsung Green (MV-3V4G3D/US) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit @ £47.99 inc VAT
nonl2br
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.<br/><br/>
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB). <br/><br/>
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
<br/><br/>
<strong>Features:-</strong><br/><br/>
- Model Name: MV-3V4G3D/US<br/>
- Main Board: INTEL/AMD<br/>
- System: DESKTOP/SFF<br/>
- System Type: DDR3<br/>
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets<br/>
- CAS Latency: 11-11-11-28 1N<br/>
- Capacity: 8GB (4GBx2)<br/>
- Speed: DDR3-1600 (PC3-12800)<br/>
- Test Voltage: 1.25-1.55V<br/>
- Registered/Unbuffered: Unbuffered<br/>
- Error Checking: Non-ECC<br/>
- Type: 240-pin DIMM Low Profile<br/>
- Warranty: Lifetime<br/>
<br/><br/>
<strong>
Overclocking Features (Not Guaranteed)</strong><br/><br/>
- 1600MHz (7-8-8-24 1N) @ 1.40v<br/>
- 1866MHz (9-9-9-27 1N) @ 1.40v<br/>
- 2000MHz (9-10-10-28 1N) @ 1.45v<br/>
- 2133MHz (10-10-10-28 1N) @ 1.45v<br/>
- 2400MHz (11-11-11-28 2N) @ 1.50v<br/>
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M<br/>
Was £59.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
picked some of that samsung up on saturday, was gonna get it on friday but glad i didnt now :D
on a side note..
got the 3570k oem on offer and the gigabyte ud3h board with the free boogiebug mousemat too.
...on the whole, a nice days shopping methinks :D
