Need for Speed Unleashed 2
cpa
cpa
12 Jun 2012
I installed need for speed unleashed 2 on my PC two days ago and have problems playing it. The screen seem to be in slow motion so it takes forever just to complete the evaluation drive. The game is also taking 15 minutes or more to load. What can I do to rectify this please?
Win 7 Home Premium
ATI Radeon 3200 integrated graphics card
AOC E2343F Monitor
I have used it to play Need for Speed: Hot Pursuit without any problems at all and never had this slow motion, freezing screen then. So it has to be something else.
Can a knowledgeable person recommend a graphics card i could use as upgrade please? I was looking at Geforce GTS 430 ..........
Different engines and different minimum requirements.
I am not too sure on what the minimum is that you would be able to get away with is, someone else will be able to tell you that. But it would also be helpful to know a bit more about your current machine, like what processor and what power supply do you have.
Also, do you have a budget in mind of what you would like to spend?
AMD PHENOM II X 4
680 WATTS POWER SUPPLY
Would a Radeon HD7750 play the need for speed unleashed 2 or should i go with radeon hd6670. Quick answer appreciated pls as i am in the shop.
