7850 Idle Crash
18 May 2012
Hi, I have just built my first pc and have received several BSOD due to my GPU.
I have looked around and seen that it not that uncommon.
I have a Sapphire HD 7850 2048MB. Everything works fine until I leave the pc and the screen idles.
an you shed any light on the situation and a possible solution?
Many Thanks.
Are you using the 12.6 drivers? or 12.4? 12.4 crashed a lot during idle, no idea about 12.6.
Try rolling back to 12.3? Or the latest 12.7 betas?
Don't update the BIOS via Windows. Stick it on a pen drive and use the inbuilt BIOS flasher on the motherboard (which can be accessed through BIOS).
As for updating drivers, make sure you uninstall the current ones through control panel and device manager, could be just me but I seem to find the latest drivers not installing over the top properly.
+1 for removing old drivers first. This can lead to problems.
