- 27 Nov 2006
- Coventry
Ordered a Corsair 650D and would like to put a 140.2 rad in the roof. Specifically the "Hardware Labs Black ICE Radiator GT Stealth 280".
http://www.overclockers.co.uk/showproduct.php?prodid=WC-021-BX
Which 140mm fans would you guys recommend? I know that rad has a high amount of fins, so guess it will need good air pressure. But I'm struggling to work out what's best. I would like the fans to be silent though, probably run through a fan controller too.
have you run the 140s any higher? How does the sound compare to other fans? Btw from looking at the Viper it looks like it is just an Apache but it can go 300 RPM higher.
