EDIT: FINISHED BUILD, picture post 18.
Thanks to everyone for advice.
Hey Folks,
Was going to spend this money to get myself a new laptop but couldn't find one that would satisfy me spec and built quality/appearance wise. So decided to spend the money on upgrading / or actually pretty much making a new build.
The only parts I'm keeping from old pc is
1) hard drive, 2) optical drive and 3) PSU(decided to upgrade too afterall)
Will be my first time doing a watercooled build so I am quite clueless as to what to get, how many tubes, claps, width of it, comparability.
I have £2,000 to spare but wouldn't mind if the total cost of build is less than that
Was thinking on the lines of watercooling both cpu and gpu, was thinking gtx 680 and i5 ivybridge (although not sure should I go with i7?).
YOUR BASKET
1 x OcUK GeForce GTX 680 2048MB GDDR5 PCI-Express Graphics Card £389.99
1 x OCZ Vertex 4 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (VTX4-25SAT3-256G) £206.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £189.95
1 x Corsair Dominator PLATINUM 16GB (4x4GB) DDR3 PC3-15000C9 1866MHz Dual/Quad Channel Kit with DHX Pro Connector (CMD16GX3M4A1866C9) £179.99
1 x NZXT Switch 810 Big Tower Case - Black £149.99
1 x Corsair Professional Series AX750 High Performance 750W Modular '80 Plus Gold' Power Supply (CMPSU-750AXUK) £129.98
1 x OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo £84.98
1 x Hardware Labs Black ICE Radiator SR1 360 £69.98
1 x Corsair Professional Series Gold AX850/AX750/AX650 Individually Sleeved Modular Cables - White £52.99
1 x EK-Supremacy - CPU Waterblock - Copper Acetal £51.98
1 x EK Multioption Reservoir X2 250 Advanced £38.99
1 x Mayhems Pastel - Ice White Coolant 1L £14.99
3 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £14.98 (£44.94)
1 x Masterkleer Hose Pack PVC 12,7/9,5mm (3/8"ID) Clear 3,3m (Ideal for EK Kits) £6.98
1 x Arctic Cooling MX-4 Thermal Compound (4g) £6.59
6 x EK-PSC Adapter Rotary 45° G1/4 Black £3.59 (£21.54)
6 x EK-PSC Adapter Rotary 90° G1/4 Black £3.59 (£21.54)
12 x EK-PSC Compression Fitting 10mm 3/8" - G1/4 Black £2.84 (£34.08)
1 x Alphacool 120mm x 100mm Velcro Pad £1.99
2 x Koolance Hose Clamp for OD 10mm (3/8in) £0.59 (£1.18)
Total : £1,726.30 (includes shipping : £22.20).
Hey Folks,
YOUR BASKET
