Where to sell koi/gold fish?
1 Mar 2003
Cotham, Bristol
Just moved into our new house, with it we have a relatively big fish pond there are several what I think are gold fish and one big white with black patches koi.
I don't really have any interest in keeping fish and it's already proving a nightmare keeping my 2yr old from jumping into the pond. I'd rather not let them die but where could I sell them? Bristol based.
Should try to get the length first. The Black and White ones are Shiro Koi and very large specimens are worth a few quid. The person who left may just not have realised this.
If they are somewhat special then you might get money for them from a keeper.
You can of course return them to a petshop/lfs but I doubt they will give you any money for them.
Can you give me your best guess as to the length of the koi please?
Umm dunno, the biggun is probably over 12 inches.
Need to get rid of them as quickly as possible really, we're having the house rewired which means the electricity is off and so is the filter.
Yeah, get them out then as quickly as possible as Koi use a lot of oxygen and need a filter on constantly. You should have got rid of them first. Take them to a local aquarist shop. Don't just let them die. That's cruel.
They wont die without the filter on for a while, what rubbish.
In most cases the filter doesn't even aereate the water anyway.
Of course it does! A filter returns water to the pond, disturbing the surface, thereby increasing surface disturbance and surface area and raising oxygen levels. If there's no electric, there's no water turnover at all which lessens oxygen and no filter means no fish waste is being broken down (biological filtration) which in turn leads to high levels of ammonia which will quickly kill fish.
This fellow lives nearby to me. This shows you what happens when there's no electric supply. http://www.newsshopper.co.uk/news/4...s_worth_of_fish_die_during_power_cut/?ref=rss
Fish saved, called the sparky and he's hooked them up with an extension lead.
Sad as it was I would suggest his pond was too small for the number of fish he had.
My dad has a rather large pond, and the fish will be perfectly fine for several days if the pump/filter is off.
Also not all filters will return the water above the surface, a number of filters will delivery the water back under the surface.
Help! It turns out I didn't save the fish, the power was plugged into a pump for the fountain not the filter! A couple of little ones dead already this morning, desperately trying to save the rest!
After a bit of googling I found the below which is most like my pond I believe
If your new pond has to be built on a budget then it is still possible to use a bottom drain and good standard filtration system. In this example below the pond has been constructed using a butyl liner with only block walls. The base has been simply carved from the soil and has sand and a membrane between the exavation and the liner. Using this simple construction method it is possible to build a pond which is both good for koi and your wallet.
The water feeds the filtration system via a central bottom drain incased in reinforced concrete. The water enters a multibay system which typically contain brushes, japanese matting and large aggregate materials which trap particles and provide the bacteria with a surface upon which to perform the nitrification process. The waste from these chambers are simply purge periodically from the system using valves on the base of each chamber. The clean water is drawn from the filter system by a dry mounted pump, passed through a Ultraviolet clarifier to kill algae cells in the water, and out through a mid or top return to the pond. mavity multibay filter systems work best when the turnover is at least 60% of the pond volume per hour. An advantage is that the pump can be low pressure and low running cost.
Now I have two chambers back one with black brush type things, and the front one has green spaghetti, the two pumps were both sitting in the front chamber, the pump for the fountain which was on was taking directly from the chamber and spraying into the pond. The pump which goes through the UV thingy and then out of a pipe feeding over the top of the pump wasn't on. What I've done and hope I've saved the day is disconnect the pump from the fountain and re-connect it to the UV thingy and then shove the pump underneath the green spaghetti. The water appears to be going through the UV thing but I have not idea if it's actually doing anything. How do I tell?
Setup looked something like this.
