creaking clicking sound?
10 Feb 2011
hi every now and then when i do certain things like open websites or folders the front of the computer makes like a creaking clicking sound. Could this be the Hard drive or a loading sound?
thanks.
Does it sound like this?
http://www.youtube.com/watch?v=J09pWNQPK7U
Edit: You may want to edit your sig a little too.
"You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you"
sounds like its the HDD,what PSU have you got ?
and btw thats not his sig but a list of his specs for us to help him
from 1 of the 3 reviews of the product on OCUK....
I agree with the other 2 posts, this drive does makes a strange noise when about to seek, It also has me concerned that is on the edge of a fail ran a full format an drive has formated fine with no errors got to admit though am a little concerned now this is the 3rd post
So you think it be safe to keep using it and its just normal for this kind of HDD as i can put up with noise i just didnt want it to die on me?.
I would think it's fine if there are no errors or performance issues.
The first time I heard that in a PC I was confused too, but it was a pre-built PC, and both PC's with the Barracuda's as boot drives have been in daily usage for about 4-5 years and they're absolutely fine, the noise hasn't increased or anything and there are no performance issues :)
