Artic cooler 7970 installing... now changing PCI slots...
10 Jun 2012
Hi guys ,
Just finished installing the artic 7970 cooler on my sapphire. As mentioned in a previous post , I can't install the card in my PCI 16 times slot as the hd trays of my CM 690 II get in the way ( fitted with rivets). However I was able to unscrew the lower hd trays , giving me plenty of room if I were to install the card in the PCI2 8 times.
Would I be getting less performance out of the card if installed in that slot?
Would I have to re-install the drivers or would Windows detect it automatically ?
I really appreciate any help you people can provide me...
PS: Installing the artic cooler 7970 isn't as daunting as it may appear... it just takes plenty of time . Really recommend it !
On x8 slot your card might lost 0-3% performance...but that's barely noticable when under actual gaming environment as if you imagine let's say you lose 3% performance, 40fps drop to 38.8fps, or 60fps drop to 58.2fps...that's hardly worth crying about at all :p
As already said, the performance hit should be negligible. Also, step by step guide of you fitting it, or it didn't happen! J/K
Let me know if you are happy with it. I really want one.
How did you find the fitting? did you use the glue for the heatsinks? I tried akasa thermal pads, they fell off lol. used glue instead, solid as a rock. Cool and quiet now. Awesome cooler tbh
Fitting was simple and I did use the glue provided...
Mix it for 5 minutes
Let it stand for 15 minutes
Apply and let it cure for a minimum of 5 hours. I personally left it for over 15 hours just to make sure.
I really can't stop recommending this cooler. My temps while playing Bf3 ( 1125/1575 oc) have never exceeded 47 degrees... but the main thing is that it is dead quiet. I can't stress that enough.
If I had a much bigger case and some extra cash , I would just buy another reference 7970 and slap the cooler on for crossfire.
Just get it ! Best money I have spent on my rig in a while !
My thoughts exactly, Although, i have xfire, albeit 6950s, the xtreme is so so good.
