£700 max gaming pc - First time builder
6 Nov 2011
Hi this will be my first time building a gaming pc. My budget is up to £700. I only need the system, no need for monitor and os and keyboard and mouse.
Can anyone also recommend me what tools I will need to buy? I have a screwdriver but I'm afraid that certain screwdrivers may mess up parts like the motherboard?
why not use the B grade HDD from my spec and use the money saved to get a better 7850 with a higher overclock?
YOUR BASKET
1 x MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards £194.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £179.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x Corsair Carbide 300R Mid Tower Case - Black £59.99
1 x Cooler Master Silent Pro Modular 500W '80 Plus Bronze' Power Supply £54.98
1 x Corsair Vengeance Blue Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9B) £44.99
1 x **B Grade** Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (HD-252-SE) £37.99
1 x Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £24.12
Total : £692.04 (includes shipping : £12.50).
lil more cash to get xfire support (better mobo and PSU)
YOUR BASKET
1 x Sapphire HD 7850 2048MB GDDR5 PCI-Express Graphics Card £179.99
1 x Asrock Z77 Extreme4 M Intel Z77 (Socket 1155) DDR3 Motherboard £101.99
1 x Cooler Master Silent Pro Modular 700W '80 Plus Bronze' Power Supply £79.99
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £49.99
1 x GeIL Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) £43.99
Total : £713.05 (includes shipping : £12.50).
A bit naff if I say so.
Getting a ATX sized motherboard will provide more distance between the two cards for airflow.
I also wouldnt touch a ASrock board again, buying a better Gigabyte board,
http://www.overclockers.co.uk/showproduct.php?prodid=MB-390-GI&groupid=701&catid=5&subcat=2261
Is a much better choice, 3 year UK based warranty and the full size ATX layout.
Yeah, i wouldn't Xfire/SLI on a mATX board. The second card could cover bits for external cables, such as Front audio and front USB. And the thermals would be much worse (as stulid stated :))
Yes the GB mobo has a longer warranty (1 year more) and is a larger mobo but is also more expensive. The argument over spacing is nonsense. If you fit an ATX mobo into a midi tower case (wether it be the Zalman or the corsair), should you add a second GPU it will be very very close to the PSU which blocks the second cards air supply. So it's tit4tat.
Rather than **** me off, why not spec a build and balance out the budget better than me ;)
Expensive by just £8, hardly life threatening.
Also the extra spacing offered is more favorable as two cards wont be sitting on top of each other, allowing more, cooler air to circulate between.
