Group Policy is still in control! Windows XP
26 Feb 2004
Hampshire, England.
Hi guys,
I've got a formerly networked machine at work that I got from another department. I've removed all of the unwanted user accounts etc. and I am just left with the original administrators account, however I suspect that another user had installed group policy at some stage and has disabled a lot of features that I need; control panel, add/remove printers to name but two. I know I could just flatten it but I really need the software on it, so that isn't really an option :(
I've tried installing group policy as admin but I get the standard 'you do not have sufficient rights' message that you see in these situations...
Any ideas, I there anyway I can take control of this machine again?
Thanks.
I haven't got access to a lot of the software mate, some of it was installed from floppy...
The machine is 100% I just need to join it to our domain which I can't do because I'm locked out of the control panel :mad:
There must be a 'Microsoft' way, surely?
The domain admin account credentials might still be cached on the machine. Get one of the domain admins to log into it and remove the local policy via that account?
Also, why do you need cpanel to join it to a domain?
Right click Computer > Properties or Windows Key + Pause/Break.
Chances are if you cannot access the CP then you wont be able to join a new domain anyway but worth a go?
That will be blocked as System is an applet inside of Control Panel.
