.Shame they don't do the 0% anymore
How does Barclays fair out in regards to given out credit? Thinking about using the finance option myself!!
Think it would be based on your income (if you work) or your current financial rating.
I'm only 19 myself so I have no clue about this yet...
/learningcurve![]()
) but then others being refused with what they thought of a good credit history.I heard of ones being offered finance even with a few credit cards and high balances (Like myself) but then others being refused with what they thought of a good credit history.
Im also poised between the fact that i would like to have it before October when i start my degree to which i will be award a grant but i dont know how much. Basically, should i take the Retina model over 24 months or 36.
Minus any learning grant i can get the retina entry model from Apple for £1558 which includes free 3yr Apple care and £70 itunes gift card
It won't be £1558 once you include the interest charges, more like £2000 I should think, which is a crazy amount of money for an already in debt student to spend on a laptop!
9 months 0% available here www.andertons.co.uk They do not inflate the prices either, only issue is they don't get many in but you can still custom spec etc.
Your finances are your own issue but Apple laptops are expensive so if you can't really afford one maybe its better to get a used mac or a normal PC based laptop which will give you the same spec for a lot less money?
just me 2p worth.
Personally, unless you're going to see a return on the investment, I think financing £2000 worth of computer is a bad idea. And that goes for any computer, not just Macs.
tbh I'd go for one of the 13" Airs.
If anything id go the ordinary 15" as the 13" is just too small. I want as much useable screen space as possible. Im going to pop up to Currys next week maybe just to see exactly how good teh Retina display is and if im not totally gobsmacked, that will at least rule that model out. Does the SSD make a real big impact over the standard HDD's?
