16GB of RAM for Photoshop or will 8GB be ok?
6 Jan 2006
Plymouth
Hi guys.
Currently I have 4GB and my RAM gets blasted and slows my PC right down when using PS so I want to upgrade but I'm wondering if 16GB would be wasted and that perhaps 8GB is the better option?
Can anyone advise please?
You need a 64bit o/s to make use use of 16gb of memory.
If you work with large files, then the extra memory is very useful.
With RAM being so cheap, I'd recommend changing to 16gb. 4x4gb or possibly 2x8gb if you want the option to have 32gb in the future!
Photoshop will munch as much RAM as you can give it, so definitely 16Gb.
A fast SSD as a scratch disk will help performance a lot too.
Ok cool, 16GB it is then! I will get 4x4GB as my motherboard only supports 16GB so an upgrade to 32GB wouldn't be possible.
An SSD would be nice but I don't like the price per GB for them at the moment.
Cheers.
I used photoshop on my old 3GB RAM pc, And that ran pretty much perfect.
But 16GB would be the better option.
Cheers.
An SSD whilst being expensive per gb is very very very cheap per performance increase. Everything feels a little bit snappier.
Storing the psd on an SSD whilst working on it would give a huge performance increase.
Once you've got 16GB you'll never look back.... Running a large VM environment with 16GB RAM and with the VMs on SSD is amazing for me, super-snappy performance and I'd never go back!
