Gaming laptop for £400~?
12 Apr 2010
London
Hi there,
I have been getting really bored of my PS3 lately and have a mid range 2010 MBP so don't really know how well that will handle games on Windows with bootcamp. Does anyone know?
So was looking at getting a decentish laptop for some CS etc, maybe bf3 if it could run it half decently.
It wouldn't be for anything major like video editing etc etc just a bit of light gaming now and again.
Budget isn't big, talking about £500 absolute top, ideally closer to the £400 mark and have looked around at ASUS/ACER laptops and it seems to be about the £550-600 mark before the specs start to look tasty.
Anyone got any ideas? Or any reports on how well my MBP would cope? As all I would on that would be to up the ram to 8GB and buy a copy of Windows.
What's the spec of the mid range 2010 MBP?
It's a 2.53GHz Intel Core i5, 4GB ram, 500GB hard drive with a NVIDIA GeForce GT 330M with 256MB of GDDR3 memory
Running Lion. I would also upgrade the ram for 8GB if I went down this route
Most probably going to have to look second hand or be super lucky on the Dell Outlet site.
Gaming laptops usually come in at around £600 "/
You could download a version of Windows 7 and use the trial and see how it works (google windows 7 iso). I have no knowledge of Macs running windows I'm afraid
I recently bought an Acer Aspire 5560G. It has a Radeon HD 7670M as well as onboard graphics, which are used in a crossfire configuration. 4GB ram and 500GB hard drive.
Only downside is the cpu, which is an AMD quad core. I can't say where I purchased it, but a quick google search of the model code (NX.RUREK.001) will bring up some results, and the place I purchased from may or may not be the third from top. I paid £378 for it brand new.
This is a great laptop for the price. Drop in a 120/128GB SSD, overclock the CPU (should do 2.2-2.3Ghz on all four cores) and you will be set.
I am sorely tempted by one of these for my wife (L4D / Minecraft nut).
As ^ said, those AMD CPU's can be overclocked like crazy and will help get lots of extra power out of your laptops
Theyre good little machines them!
You weren't wrong.
Hi, I'm in a similar position for myself so figured I'd hijack this thread rather than start a new one. Been a while since I have gamed and never really gone for the laptop option but looking to do some light gaming and looking for a lappy for under 400 quid. Probably want to play things like Football Manager, maybe a bit of WoW if it can handle it, also was always partial to the total war games so if it can handle that sorta stuff too then great - none of it has to be on max detail or anything.
The laptop above looks great, but not knowing how things compare any more I thought I'd post up an alternative that I found, wonder how it compares. Comes in at just under £400.
HP Pavilion G6 Laptop
SPECS:
Processor: AMD Quad-Core A8-3520M (1.6 GHz up to 2.5 GHz with AMD Turbo Core, 4 MB L2 cache)
Operating System: Genuine Windows® 7 Home Premium 64
RAM: 6 GB (1 x 2 GB, 1 x 4 GB)
Graphics card: AMD Radeon HD 6620G + 7450M Dual GPU (1 GB DDR3 dedicated)
Screen type: 15.6" HD LED BrightView (1366 x 768)
Hard drive: 750 GB
Optical disk drive: SuperMulti DVD±R/RW with Double Layer Support
Memory card reader: Multi-Format Digital Media Card Reader
TV Output: VGA + HDMI
Sound: Altec Lansing Speakers
USB 2.0 x 3
Size: W 374 x D 245 mm
Thickness: 36.3 mm
Weight 2.55 kg
I guess the only other thing is if it is worth waiting, ie. if prices are about to start dropping like a stone for any reason (eg. new glut of hardware coming out). Obviously new stuff is always coming out but if there's a particular push coming soon maybe it's worth waiting a month or so.
Thanks for any advice in advance.
