A discussion of camera straps..
27 Dec 2006
Northampton
This you Raymond? ;)
Basically I've been lugging my 5DMKIIs around and the thought of having two cameras on each shoulder is a bit tiresome and having to switch between the two. My main problem is the straps at the moment because getting them 'flat' and not twisted can have an effect how I hold my camera and line up my shot.
Any good products to suggest what straps will work for this combo?
I have a Black Rapid strap and it's awesome, they do some good dual camera systems as well but I'd feel like a dick using it. I prefer to just use a single Black Rapid and then have the other camera around my neck when I'm using both.
I went for the below strap, with Black Rapid fasteners. The main reason I went for this over the other cheap straps was because it was all black, there are no ugly yellow bit's anywhere so it shouldn't look out of place over a black shirt.
Besides, if it works.. I'm not in the least bit bothered if anyone thinks I look like a dick. :p
http://www.ebay.co.uk/itm/280857732...cat=0&_nkw=280857732913&_rdc=1#ht_4440wt_1396
