Man of Honour
- 5 Oct 2008
- Kent
They're not using them for our protection. They're the GB athlete for the 1000m race. Didn't you know?
and SAMs wouldn't be deployed on hijacked airliners.
I've just heard a rumour that Blair and Bush are planning to invade London as there are Weapons of Mass Destruction™ there.
Oh and there might be some oil under the ground in that area as well but that's just a coincidence obviously.
Something tells me they will have armed guards to stop people getting on to the roof, and its not like we have to worry about people stealing planes and flying them into SAM batteries![]()
That straw you're clutching died of strangulation a long time ago. Did you even think before posting that?
that post made no sense dude.Which is not the point you were trying to make, at all.
What security measures do you think are realistic for such a global event?
Wrong. It was pointed out that the effective range of the missiles is too short, and the aircraft (should one get shot down) would land in London. Not "hit the target." Having even a small aircraft come crashing down in London would be catastrophic.It was and it is the point I made.
Lets recap the whole argument: Some guy reckoned that the range was so short on the missiles they would be pretty pointless at stopping an aircraft and the wreck would probably hit the target anyway; Firestar_3x pointed out they have more than a 30cm range; you told him the range was much shorter than he would expect and they need to be able to see the target; I pointed out they can use radar to target it before it comes in visual range and later backed it up with links to the army's website; you started resorting to insults.
The is nothing bad about being wrong but there's no need to be childish about it.
From air attack? Very little it's just simply not going to happen the olympic stadium/park just isn't the right target. If the terrorists learnt one thing from 9/11 it was that tower blocks make much better targets.
The Rapier Missile system has a maximum operating range of 8.2km. That means it doesn't even cover the borders of London.
This will ultimately mean that should there be a threatening aircraft, it will be a lot closer than you think before they (the Rapier missiles) can shoot it down, and it will have a catastrophic effect.
It is also limited to line of sight. There must be a clear line between the rapier "base unit" and the target, and the missile throughout the entire flight of the missile for it to be used. You've been mistakenly believing the Rapier system is capable of long-range AA, also known as "beyond sight" AA. I've pointed out to you a number of times that this is false, with facts to back it up - to which you've gone and had a quick Google, found something that looks like a counter argument (such as the "BlindFire" system) and posted in this thread without actually reading/understanding what it is you are posting. You have been wrong, every time. Now you are trying to claim the topic of the discussion is not what it was to weasel out of it.
You, ubersonic, are wrong.
SAMS are laser guided, what are you waffling on about terrorists buying fighter jets for?
You could fire one at your left nut if you wanted to.
I understand the Rapiers are being deployed in a number of locations, some inside the M25 and some outside it. Your argument rather seems to assume we only have one.
I also understand that the Starstreak systems are being deployed within London proper as another layer of defence. I should imaging there are others, such as the already known Typhoon fighter aircraft. I imagine the approach is to create multiple layers.
The Shard just opened, too![]()
