Weight Loss/Virtual Gastric Band/Etc
How is that even possible? :eek:
Looking back i do wonder the same.
After 3-4 days i started getting the shakes, always tired, i had bad moods but i didnt want to give up, i wanted to lose the weight so badly.
After about a month is just became routine, wake up, go to work, if i was hungry id have chewing gum and that was it.
I almost lost my job as i couldn't concentrate properly, turned up late due to over sleeping as i was always so tired.
It was the worst 3 months of my life, but if i didnt do it, i wouldnt be how i am today. :)
Just always remember, weight loss is good just dont kill yourself to achieve it.
This last page has turned this thread, for me, from getting motivated to shift that last bit of weight, to going out and eating everything under the sun! :D
Damn you for making food look so good Raymond! :p
Calories In < Calories Out = Weight loss
The most important thing I would say is don't crash diet (Atkins diet etc) as that is not healthy. Make a lifestyle change and make it sustainable, else once you drop the weight and go back to your old habbits, the weight will come back real quick.
Just remember that weight loss does not necessarily mean just fat loss. You should aim to lose around 2lbs a week max, any more than that and you will be losing muscle mass as well as fat, and sure the number on the scales will drop but you won't be looking good by the end of it!
Best thing to do would be to calculate your maintenance calories, work out how many calories are burnt through the day e.g. how active you are, how much exercise you do, and deduct 20% to cut weight. Monitor results and adjust accordingly to keep within the 1-2lbs per week.
You should aim to try and eat about 1g of protein per lb of body mass each day. Slightly less for carbs and you also need to consume healthy fats e.g fish oils, seeds , nuts etc. Also to be drinking plenty of water.
To retain muscle mass whilst dieting you really need to be active and try and get your muscles working at least a few times a week.
If you have an Android or iPhone the "MyFitnessPal" app is really useful for tracking what you eat and weight changes etc.
EDIT:
I have found this online calculator can be very useful for working out calorie requirements etc.
http://www.1percentedge.com/ifcalc/
Although related to Intermittent Fasting, you don't have to be doing that to use this.
flipping heck you eat well, rayomnd lin
all on expenses right? ;)
I wish ! (but no family to feed so more goes in my tummy :D)
Today's breakfast
Carbs!!!! (I didn't finish it all, ate all the strawberries though)
Lunch
Apart from the cherries, the rest didn't cost much.
Cereal is Sainsbury's own brand stuff, under £2 a box
Strawberries is £1 a box, enough for 3 servings
Tuna is £1 a tin
Olives in the salad is 79p a jar
Salad is £2
I already have olive oil and balsamic vinegar in the office.
So the 2 means cost about £4
Can you guys supply more pictures of these meals your having even if they are lunches/dinners/snacks. It will be good to see it for real rather than trying to figure out how much you all eat!
I've started my own weight loss thread. In it I'll be posting pics of what I'm eating.
This thread helped tip the scales in favour of getting on with it and stopping the procrastination. Thanks to all for your input - especially Phate, because ultimately it was your rather impressive weight loss that showed it can be done.
