Spray Paint? Green? Suggestions?
Can't type for toffee
Don
14 Jun 2004
Newcastle U/T
Might sound daft..
Anyone used green spray paint on their case or in their mods?
Looking for a nice green but not too bright, any suggestions welcome.
In at the deep end with a RV03 xD
Getting the erm "champagne" colored strips a makeover and was thinking of some of thet carbon fibre film stuff
Had a Antec case a few years ago, which I sprayed 'British Racing Green'.
Would like a Coolermaster, maybe Obsidian 550D in same colour again.
Plasti-kote Super: APRIL GREEN GLOSS (mid apple green)
Plasti-kote Super: HUNTER GREEN SATIN (a good dark green)
My choice would be
Palsti-kote Enamel: GARDEN GREEN (primary/true green)
Did you get the RV03 from b-grade btw?
Get some of this before you try painting! I used some on my power supply and the side part of my Thermaltake Frio and it gave quite a good look! ;) Also no mess from spray painting either.
My choice would be
Yeah from B-Grade :)
Was watchin it for a while as the prices seemed to be slowly dropping ;)
Will have a look at the greens suggested so far.
Anyone used any of this carbon fibre film before?
As above, used it on my power supply and heatsink shroud, also forgot I used it on an old mouse too. Was easy to use with a hair dryer, and a sharp modeling scalpel to cut it.
I bought it from the auction site, can't remember the seller but there's loads of the stuff on there. I think the stuff I bought was purchased as vinyl to stick on modified cars. I think it was only like £3 for a 2 ft x 1ft piece, but I didn't need much I kinda used it for a trial.
