Tips for driving test?
Take a bottle of Coke or something like that with you, If you feel your concentration levels dropping then next time it is safe drink some. The sugars / caffeine should perk you up again. A small bag of sweets work just as well. I would avoid energy drinks though it will most lily look bad to in examiner.
Are you suggesting that he stops and has a drink during his driving test?
Relax, if you should pass you will do. Not the end of the world if you fail. Just learn from
Your mistakes. Personally I chatted to my examiner, the first guy i had was extremely untalkative which put me on edge, as i drive better while not directly thinking about it. The guy i had on my third time, was chatting to me and my instructor in the back. The atmosphere was so relaxed it was bliss.
Take a bottle of Coke or something like that with you, If you feel your concentration levels dropping then next time it is safe drink some. The sugars / caffeine should perk you up again. A small bag of sweets work just as well. I would avoid energy drinks though it will most likely look bad to the examiner.
[FnG]magnolia;22334314 said:
Are you suggesting he drinks it during his test? because if you're not then you're suggesting he has it after the test which is, you know, a little pointless.
Actually, the examiner will ask you to pull over in a safe spot several times during a test. IIRC you're expected to apply the handbrake and gear neutral. I'm sure you can take a sip before he tells you to set off again. :)
