Holiday Trosuers, yes!
Permabanned
15 Nov 2011
Yes i really am asking this one.
I go on holiday in 7 days time for the 1st time in 6 years.
So evening dress code calls for trousers. I only wear trousers when in a suite at work! Women can wear them linen things.
So what the hell can a bloke have thats smart and light weight
M&S, lots to choose from including lightweight ones for warm places. You can also buy suit trousers without the jacket.
Lightweight chinos/trousers/linen trousers :confused:
M&S should stock a decent selection at a reasonable price.
Linen trousers are a good choice (although not in white, unless you want 'special' attention). Chinos also are nice but a bit heavier.
What are "Trosuers"? (Title)
And why would you only wear them in a "suite"? What's wrong with wearing them in a normal hotel room?
Once you've resolved these important questions, try chinos or linen trousers depending on how lightweight you want to go. M&S is probably the best bet as others mentioned.
Zara have loads of really nice trousers, linen and chinos which are both smart and light for hot weather.
It's not really that difficult!
I bought a few pairs of cheap 3 quarter lengths off amazon, they were like £8.99 each and quite well made, in beige, tan and navy blue :D
1. Go out
2. Find shop
3. Enter shop
4. Select trosuers
5. Try on trosuers to ensure they fit
6. Buy trosuers
7. Leave the shop
8. Go home
1. Go out
2. Find shop
3. Enter shop
4. Select trosuers
6. Buy trosuers
7. Leave the shop
8. Go home
I need to update the list as the OP clearly needs help:
1. Go out
2. Find shop
3. Enter shop
4. Select trosuers
6. If they do not fit, repeat from Step 4
7. Buy trosuers
8. Leave the shop
9. Go home
Plus, don't forget to go with your trosures you will generally need a collared shirt (short or long sleeve - your call)
1. Go out
2. Find shop
3. Enter shop
4. Select trosuers
6. Buy trosuers
7. Leave the shop
8. Go home
Corrected:
6. Be indecisive
7. Go home
8. Ask GD
9. Ask some more
10. Be even more indecisive
11. Go back to shop
12. Your size already sold
13. Go home
14. Start again........
