**SAMSUNG 850 SERIES & 970 PROFESSIONAL PLS MONITORS COMING TO OCUK!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK have coming on Monday the Samsung 24" PLS LED Display and in approx 6 weeks we shall see the 27" 850D and 970 models, you can pre-order the 850 series now:-
Samsung S24A850DW 24" Widescreen Ultra Thin LED Professional PLS Monitor - Matte Black @ £359.99 inc VAT
Engineered with the ecologically responsible homeowner in mind, the Samsung monitor reduces power consumption by 40%;, making it much more efficient than conventional monitors. By reducing the number of LED and defaulting to standby power, which requires less than 0.3W as opposed to the typical 1.0W, the Samsung monitor is poised to make a difference. How big a difference? If your monitor saves 120W each day, that’s the annual equivalent of eliminating 10.8kg of CO2 emitted from an oil-burning power plant—which produces the same effect as planting four pine trees.
Choose a monitor that allows you to reduce financial and environmental costs as well as increasing productivity. The Samsung SA850 LED Business Monitor is designed to use less power, so you can cut bills and be kinder to the planet. A high 2560 x 1440 pixel resolution also makes sure you’ve got screen space for all your work and lets you see it all in greater detail. You’ll see images and video with stunningly natural colour thanks to sRGB support, and a 178 degree viewing angle gives great viewing from a wider range of perspectives, so it’s perfect for sharing presentations and more.
The Samsung SA850 Monitor showcases an astounding WQHD display with 2560 x 1440 pixel resolution, which is four times the resolution of HD (720p). It is perfect for businesses and industries that rely on access to extremely fine monitor detail. The wide screen, which features dual link DVI and display port, allows for more detail to be viewed and is ideal for work places such as hospitals, clinics and studios. The enhanced screen resolution provides greater efficiency and quality, and really is the must-have business tool.
Whether it’s video from an HD camcorder or photos from your digital camera, sRGB support makes sure that nature looks just as natural on your Samsung Monitor as it did when you shot it or filmed it. No matter what digital device the image was captured on, it’s as picture perfect on screen as Mother Nature intended it to be. So you can view, edit, and save images in their original format with no picture quality degradation whatsoever — which translates to 100%; pure digital satisfaction.
Provide employees with an optimal viewing experience in the office with the reasonably priced Samsung Business Monitor. While conventional monitors have a viewing angle of 170 degrees horizontally, the Samsung monitor has an extra wide viewing angle of 178 degrees. The additional 8 degrees is particularly useful when sharing on-screen information with one or more coworkers or presenting your ideas to clients. The Samsung Business Monitor has improved its vertical viewing angles by 18 degrees, making it the perfect display for giving presentations in front of a large audience or when viewing other content such as a video.
Maximise your viewing experience with Samsung’s superior PLS technology (Plane to Line Switching). Regular screens suffer from what is called Colour Shift, which reduces the picture quality and colour when viewed from an acute angle. The SA850, which can cover an amazing 178° viewing angle both vertically and horizontally, boasts a crisp and detailed picture by maintaining true-to-life colour, even when viewed from extreme angels, so the experience is always vivid and brilliant.
The Samsung LED Business Monitor SA850 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer’s body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA850 Monitor can rotate 90°°° degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA850.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA850 is the perfect choice. It features an innovative new detachable adaptor, which allows the monitor to be easily moved and installed. From physically moving the monitor with the carrying handle to quickly installing, the SA850 is ready to deliver an efficient and clean work space. The SA850 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimising your office space is now easily achieved with the Samsung LED Business Monitor SA850
Utilising Samsung’s dual input feature, two PCs can now be viewed simultaneously on the one monitor screen. The SA850’s Picture by Picture capabilities allow for a far more flexible approach to work and ensure that content can be easily accessed, even if they require different PC access. This is perfect for businesses handling large and complex content from two PCs, but prefer to view it on one convenient screen.
As the work environment becomes increasingly modernised, it is essential that monitor also have the latest technology. Samsung SA850's USB Hub with USB 3.0 technology, which provides super-speed data transmissions, is the ideal solution for connecting all of your mobile devices. With a maximum speed of 5GB per second and uncompressed Full HD video transmissions, the USB Hub effortlessly brings your content together on one convenient monitor.
Eco saving makes saving energy easy, it adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%;, 25%; and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50%; saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
Take the guess work out of eco savings with Samsung’s new Energy Tree feature. For the first time, you can now know exactly how much energy you are saving through your eco modes such as the Eco light sensor and the Eco motion sensor. Through an intuitive energy saving status, which can be displayed either intuitively or graphically, you can keep tabs on your efforts to make the world a better place.
Features:-
- 24" (16:10)
- 300cd/m² Brightness
- DCR Mega 8 Dynamic Contrast Ratio
- 1920 x 1200 Resolution
- 5ms Respond Time
- 178° / 178° Viewing Angle
- 16.7 Million Colour Support
- Inputs: 1x DVI, 1x DisplayPort, 1x Analogue
- 3x USB 3.0
- HAS (150mm)
- Tilt / Swivel / Pivot
- VESA: (100 x 100, 100 x 200) Available
- USB 3.0 Super Power
- 3yr Warranty
Was [£399.95] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Samsung S27A850D 27" Widescreen Ultra Thin LED Professional PLS Monitor - Matte Black @ £569.99 inc VAT
Features:-
- 27" (16:9)
- 2560 x 1440 Resolution
- 5ms Respond Time
- Inputs: 2x Dual Link DVI, 1x DisplayPort
- 3x USB 3.0
- HAS (150mm)
- 3yr Warranty
Was [£599.99] Inc. VAT
Only £569.99 inc VAT.
ORDER NOW
Needless to say these are absolutely stunning and are another option to the LG IPS options from DELL, Hazro and DGM.
The 970 model we shall be listing shortly, or next week for Pre-Order, but for those wondering about price, well its mega expensive at approx £800 :eek:
Looking good. Sorry to seem dumb here, I see viewing angles are much better, but how much better is it than VA/IPS panels when it comes to contrast/colour accuracy? Sell it to me over my NEC 24WMGX3.
Hi there
Keep the NEC 24WMGX3, it was seriously the best monitor of its time and NEC actually sold them at a loss, it was a simple case of look at what we can do and its still one of the best if not best. :)
You don't need to upgrade!
I'm a terrible sales person, haha. :)
Good to see some more choice on the 1900x1600 Mons.
I just don't like 1080. looking forward to seeing one of the 970s in action
What took you so long? I've had an S27A850D since November and am delighted with it. It would probably be even better if I dusted the screen..... :D
