- 18 Oct 2002
I've been out of the PC hardware scene for a couple of years. I'm still running a 5830 with a hard volt mod and water and I'd like to replicate something similar on a modern graphics card.
I don't want to be power-limited and have a ridiculous amount of heat-removal available (radiator is 30cm x 40cm and can be fitted with four 140mm fans).
Gaming will be done @ 2560 x 1440.
I'd be happy to spend up to the GTX 670 / Radeon 7950 level (i.e. max £300), but would much prefer to spend less if it means I get a card that can easily have more voltage put through it and hence give more bang for buck.
e.g. I would rather spend £200 and get a 50% overclock than £300 and get a 25% overclock even if the latter was faster overall.
I gather that most cards have software voltage adjustment - which ones have the most headroom there or can be BIOS / software unlocked to unlimited voltage?
I also gather that the ASUS GTX 680 has a PCB with solder points already built-in to allow easy hard mods!
It's a shame I don't want to spend that much money though.
Thanks for any advice!
It's a shame I don't want to spend that much money though.Thanks for any advice!
The usual suspect for an overclocker - i5 3570K.
