[SOLVED] Trouble Connecting XBOX 360 to PC (Windows 7)
I've been having my Xbox 360 Live connected to my PC via Ethernet for ages and was a happy lad until today where I had a problem with a PC game which, as a noob, typed my problem in Google and found a solution. It involved:
in Command Prompt.
Unfortunately since then my Xbox does not connect to the network (I'm not talking about internet, that will be the next step. I'm talking about the Xbox-PC connection). I have tried factory resetting my Xbox's network settings, setting the connection to Manual and Auto with no success.
EDIT1: In my Xbox's network settings, when I set the connection to Auto it identifies the following:
And these are the details I get from the Network Connections in Windows
More info:
EDIT2: Trying to connect to network manually, with no success:
From IP Config:
Please help me!
Thanks in advance!
UPDATE: Tried using my Xbox with my brother's laptop, everything was fine. Something is going wrong with my PC's settings. Not sure what.
Code:
netsh int ip reset resetlog.txt
netsh winsock reset
in Command Prompt.
Code:
IP Address: 169.254.37.231
Subnet Mask: 255.255.0.0
Gateway: 0.0.0.0
DNS Server (primary): 0.0.0.0
More info:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ping yahoo.com
Pinging yahoo.com [209.191.122.70] with 32 bytes of data:
Reply from 209.191.122.70: bytes=32 time=147ms TTL=46
Reply from 209.191.122.70: bytes=32 time=149ms TTL=46
Reply from 209.191.122.70: bytes=32 time=144ms TTL=46
Reply from 209.191.122.70: bytes=32 time=143ms TTL=46
Ping statistics for 209.191.122.70:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 143ms, Maximum = 149ms, Average = 145ms
C:\Windows\system32>nbtstat -n
Local Area Connection:
Node IpAddress: [169.254.164.160] Scope Id: []
NetBIOS Local Name Table
Name Type Status
DANKEEPSIE <00> UNIQUE Registered
WORKGROUP <00> GROUP Registered
DANKEEPSIE <20> UNIQUE Registered
WORKGROUP <1E> GROUP Registered
WORKGROUP <1D> UNIQUE Registered
..__MSBROWSE__.<01> GROUP Registered
Wireless Network Connection:
Node IpAddress: [192.168.1.228] Scope Id: []
Name Type Status
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Dankeepsie
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom 802.11n Network Adapter
Physical Address. . . . . . . . . : 00-22-3F-35-F4-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::a458:b4c6:bef1:d7fa%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.228(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 15 July 2012 23:37:42
Lease Expires . . . . . . . . . . : 17 July 2012 00:05:32
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 218112575
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-92-E3-A6-00-1F-D0-DA-89-14
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek RTL8168D/8111D Family PCI-E Gigab
it Ethernet NIC (NDIS 6.20)
Physical Address. . . . . . . . . : 00-1F-D0-DA-89-14
Link-local IPv6 Address . . . . . : fe80::85ac:b279:b56d:a4a0%10(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.164.160(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
DHCPv6 IAID . . . . . . . . . . . : 234889168
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%2
fec0:0:0:ffff::2%2
fec0:0:0:ffff::3%2
Tunnel adapter 6TO4 Adapter:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #5
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{71C5F03E-94D8-4358-9F08-49444C45C5E0}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 26:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:1030:157e:ade8:e3d4(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::1030:157e:ade8:e3d4%34(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{F35106A6-51AF-499C-A92E-6A02D70414B8}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Name Type Status
Name Type Status
fec0:0:0:ffff::2%2
fec0:0:0:ffff::3%2
erred)
From IP Config:
Code:
Please help me!
Thanks in advance!
