Looks right to me. If you're going to build something then go for the best price/performance ratio.
Indeed, the spec in its entirety is:
- i3 2120
- Asus H61 MB
- 4GB DDR3 1600MT/s memory
- C300 64GB SSD
- Arc mini
- XFX Core 450w PSU
All of this come to a little over £250 as I already had the SSD.
I dropped in a HD7770 for £100 and the system is running Win 8 RP x64. If I factor in the SSD the entire system cost a little under £400.
Not bad for all out max settings at 1680x1050.
I could have done it cheaper by going used or scrimping on say the CPU but I am pleased with the overall result.
