Advice on PSU please?
OP:
As mentioned above the Corsair AX 650W PSU is the one to go for. Expensive yes, but still within your budget range mentioned above. Is a rebadged Seasonic PSU so is of very high quality and extremely quiet. I can hardly hear mine, even under load. Also fully modular for a nice tidy case as well. Would be a good investment as It should last for years.
The XFX mentioned above is also a good choice, is a Seasonic PSU also but is only semi modular unlike the AX. Quite a bit cheaper though which is an advantage!
OP:
As mentioned above the Corsair AX 650W PSU is the one to go for. Expensive yes, but still within your budget range mentioned above. Is a rebadged Seasonic PSU so is of very high quality and extremely quiet. I can hardly hear mine, even under load. Also fully modular for a nice tidy case as well. Would be a good investement as It should last for years.
The XFX mentioned above is also a good choice, is a Seasonic PSU also but is only semi modular unlike the AX. Quite a bit cheaper though which is and advantage!
Think I might be learning towards the AX 650W seeing as 3 people have recommended it to date :D.
Yes you're correct but it doesn't restrict airflow, it prevents the desired heat loss form heatsinks. There are many heatsinks in a psu.
I just opened up the PSU to check inside and it's all clear so I think the PSU is being pushed to its' limits, so to speak.
Ahem... yeah.. I'm hoping modular will sort that mess out and can remove the bottom drive bay on the right :P
