Fan Controller with a reset button?
22 May 2011
Manchester
I've been searching the internet for about 30 mins now, and I've found nothing that fits my ideal spec.
What I really want is a 4 fan controller with a button on it. That button needs to have a reset button on it, the pins are the same as a case reset button but I want to use it for my CMOS Reset, instead of using a jumper. I have a small button inside the case installed at the moment but want one externally, ideally built in to a fan controller. Am I asking too much? Or shall I just get a 4 fan controller and be done with it? :rolleyes:
I can't imagine there would specifically be a fan controller for that purpose. It could be possible for you to modify one though. Shouldn't be THAT hard?
http://www.evga.com/forums/tm.aspx?m=200240&mpage=1 - PCI Bracket
http://www.overclock.net/t/559214/diy-bios-reset-switch-tutorial - Can be modded onto a controller + looks better.
You can get switches that'll fit those watercooling hole grommets you get on most cases. Just wire up one of those and reach behind to flip it. Or install in a hole you make in a optical bay cover.
Looks like that Hydro Pro LED switch simply closes a loop of wire that breaks the circuit or makes the circuit to their Fan's LEDs. It's just a latching SPST switch. Neat and simple.
Now whether you could use this depends on the switch you have at the moment.
