Hi all,
I am in the process of making my computer (near enough) silent. I have recently changed the stock gfx card cooler to an Arctic Cooling Twin Turbo II and this has made a difference. Now if I unplug my intake fan (stock one that came with my Cooler Master Elite 430) the PC is near enough silent, so what I want to do is change this fan for another 120mm Blue LED fan that is quiet.
So I was just wondering if someone could suggest a 120mm Blue LED fan, with good airflow and it has to be as close to silent as possible.
At the moment the current fan is just connected using a 3 pin to molex adaptor straight into the PSU, so I think a similar connection would be good? I preferably want something that is quiet at full speed, so I can leave it at full speed and not risk having flickering LED's if I try to turn the fan speed down
If anybody wants to know more about the current fan, here is something written on it:
A12025-12CB-3BN-F1
DF1202512SELN
If I google that first part I find these specs:
And the picture shows a black fan, but mine is a clear fan with blue LED's
Anyway, so has anybody got/used a good 120mm blue LED silent fan they can recommend?
Hope you can help,
EDIT: I was thinking possibly the Cooler Master Sickle Flow Blue LED fan? Anybody used one? They seem reasonably priced and push more air than my Apache Black exhaust fan does. The Sickle Flow is 3 decibels louder though and if my Apache Black is running at full speed you can hear it which I don't really want. So does anyone know if I get a Sickle Flow, can I use a Zalman fanmate to turn it down a bit without the LED's going out or flickering?
Hmm actually just seen some reviews and people say they push a lot of air but are VERY loud at full speed
A12025-12CB-3BN-F1
DF1202512SELN
120x120x25mm
1200 rpm, 44.03 CFM, 19,8 dB
Sleeve Bearing
3 Pin
Hope you can help,
My current one dims if I reduce the voltage to it, I tried it using a friends Zalman Fanmate but the fan was not in my PC at the time, so I can't remember if it was quiet enough for my liking.
