Today Only Deals!1
Experience amazing 2560x1440 resolution and perfect picture quality at affordable price!
DGM IPS-2701WPH 27" LED Widescreen Professional Monitor - Black
The IPS-2701WPH is DGM's new WQHD resolution monitor built around LED backlight LG IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The DGM IPS-2701WPH features the same high resolution LED LG IPS panel found in the Apple Cinema Displays. Video content bypasses scalers making the DGM IPS-2701WPH ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- Panel Size: 27" Diagonal IPS Panel
- Aspect Ratio: 16:9
- Resolution: 2560 x 1440 (WQHD)
- Pixel Pitch: 0.2331 mm
- Display Colors: 16.7M
- Brightness (cd/m2): 350cd/m2
- Contrast Ratio (Typ.): 1000:1
- Dynamic Contrast Ratio (Typ.): 80,000
- Response time (ms): 6ms
- Viewing Angle, H/V: 178 degree(H) / 178 degree(V)
- Input Signal: HDMI (Max resolution on HDMI is 1920x1080), Dual Link DVI-D, DP (Display Port), VGA (D-sub 15pin)
- HDCP Support: YES
- Internal Speaker: Built-in Stereo Speakers
- Wall Mount: VESA 100 x 100 mm
- Net / Gross Weight: 7.6 / 10.3 Kg
- Monitor Dimension (W*H*D mm): 645 × 487 × 172 mm
- Carton Dimension (W*H*D mm): 720 × 510 × 130 mm
- 3yr Warranty return to base with OcUK
£329.99 inc VAT BUY NOW
Corsair Platinum Dominator has an amazing cooling solution which performs and looks great!
Corsair Dominator PLATINUM 16GB (2x8GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit with DHX Pro Connector
The Corsair Dominator® Platinum builds on the legacy of the world’s most awarded high-performance memory, adding a striking new industrial design and LED lighting effects. Like all Dominator memory modules, they are built using only select memory ICs, highly-screened for performance and stability, and feature our patented DHX® (Dual-path Heat eXchange) cooling technology, so you can push them to the limit.
The new design will look great in your current system—or your next build—and the user-swappable light bar lets you customize the LED lighting to match your rig. You even can connect Dominator Platinum to the Corsair Link system to monitor temperature and activity. It’s memory with both muscle and finesse.
- Ultra-high performance 16GB (2x 8GB) Domintaor® PLATINUM Dual Channel kit
- 16GB total capacity provides ample headroom for the most demanding user
- Ultra-low 9-10-9-27 latency
- Intel XMP (Extreme Memory Profile) support
- Limited Lifetime Warranty
- Compatible with Intel X79, Z68 and P67 platforms
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.50V
£167.99 inc VAT BUY NOW
Features:-
- HDCP Support: YES
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
