Home Hub 3 - Spec Me An Alternate?
29 Mar 2007
Swindon UK
Recently upgraded to BT Infinity and our ailing Home Hub 2 was replaced by the seemingly equally wonderful Home Hub 3. Unfortunately the Ethernet ports on the rear are so badly made the cables are either loose or just fall out, resulting in the loss or reduction in the Broadband signal.
Is there an independent router of reasonable quality (and not too expensive) which I can swap with the Home Hub 3 (the black box, not the white modem which sits under it) and still retain full compatability and speed with the BT service?
