New Build Pc [Budget £550]
7 Dec 2011
New Build Pc [Suggestion] Budget: £550
I am tryin to get a new Pc within my budget of less then £600 where i can play most of the games in high settings and near future games.....i nevah build a pc myself....but i gather needed componenets and wanted to ask u guys if its fine and if it can run games in near future?...i might try to build the PC myslef..if u guys recommend and if its easy to do it.......
Specs:
AMD Bulldozer FX-6100 6 Core 3.30GHz
Asus M5A78L-M
Sapphire Radeon HD7770
8GB DDR3 1333MHZ RAM Memory
OCZ OCZ600MXSP-UK ModXStream Pro 600W ATX Power Supply
Western Digital Caviar Blue 1TB SATAIII 6Gb/s 32MB Cache
Zalman Z9 Plus Midi Tower Case
Sony AD-7261S-0B 24x Internal DVDRWRAM SATA
TP Link 450Mbps Wireless Adapter
Total: £497.58
Is this okay..now only if i had pc building guide xd
Building a PC is easy, besides if you get stuck there are tutorials on Youtube and there are plenty of people here to help you, plus you'll save money and end up with a better performance rig!
As for what you have linked the FX-6100 is not great for gaming, given your budget either an i3 or i5 processor would be better. The HD 7750 is the same, it won't great something like a HD 6850 would be better.
I would wait for a seasoned speccer to drop by soon. Honosuseri is a good user who helped me out so I'm sure he or someone else will drop a spec here.
I have seen people...running most of the high end games like BF3, crysis etc on those 2 specs on high and ultra settings with 50-70 fps....also those 2 price are cheaper compare to what u recommend me -...-.
At what resolutions? What resolution do you plan to play at? Bare in mind that here users aim to pack the best bang for buck in your budget, that straight out is not the best PC you could get for the money.
The Youtube video Smoogels linked is the one I followed on my first build and it is very informative, watching Part 3 will probably help you too.
If you insist lol
YOUR BASKET
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £95.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
1 x MSI HD 6850 "Dual Fan Edition" 1024MB GDDR5 PCI-Express Graphics Card £83.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £82.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) £65.99
1 x OCZ ZT 550W '80 Plus Bronze' Modular Power Supply £59.99
1 x BitFenix Shinobi USB3.0 Gaming Case - Black £44.99
1 x GeIL Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) £33.59
1 x OcUK Value 300Mbps NWP300E Wireless-N PCI Express Adapter £13.98
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £12.98
Total : £593.47 (includes shipping : £12.50).
It's over £550 sorry. Did you need the OS?
You could shave off a few quid using a B grade HDD (shorter warranty), or even change to a non modular PSU. We could drop the price of the case maybe too, which would make the build look like this......
YOUR BASKET
1 x **B Grade** Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM £55.00
1 x OCZ ZS Series 550W '80 Plus Bronze' Power Supply £49.99
1 x BitFenix Merc Alpha Gaming Case - Black £29.99
Total : £556.58 (includes shipping : £11.75).
i would prolly get the same monitor i have now donwstair ..which is 21.5 inc 1080 p
If you insist lol
YOUR BASKET
You could shave off a few quid using a B grade HDD (shorter warranty), or even this PSU which is £10 less but not modular. Even change to a cheaper case maybe if you wanted which would look like this......
YOUR BASKET
Ahh no i got myself OS....i jus need a cpu ^^
I do :P
As for the monitor and resolution I reckon the HD 7750 would struggle to run BF3 at 1080 much past medium. Removing the OS would make a little more room for the possibility of a 3570K yes?
Sowwie tpyo..its HD 7770 xD
well i am here for u guys to guide me so any thing can help ^^
Good luck with all, but I would be amazed if someone got those frames with the spec you have listed. I would take the advise of forum - I am sure they will suggest 6850 way to go with either an i3/i5.
Look at this for FPS comparisons.
http://www.anandtech.com/bench/Product/535?vs=539
Still applies though :P But the frame rate would be a little higher. Still both of the above specs would outperform the one you originally linked :)
well...so do pls guide me xd
if u can get me under £550 ..with same performace or better..then i am glady happy to take your guys advice..;)
Tell me EXACTLY what you do need. Once i have all the info i can try and balance a better spec for you.
where i can play most of the games in high settings and near future games..i think thats it ?l0l..if maybe some video editing or frapsing and z9 plus be must case xd ;)
where i can play most of the games in high settings and near future games..i think thats it ?l0l..if maybe some video eiedint or frapsing ;)
Well i now know you don't need the OS but you are talking about a monitor now aswell. I'm happy to help but I don't want to spec over and over and over again.....i've done two already lol
