Hi there
We now have the crazy Toxic card available for Pre-Order from Sapphire. Stock is due in 1-2 weeks:-
Sapphire HD 7970 TOXIC GHZ 6144MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £499.99 inc VAT
The SAPPHIRE HD 7970 6GB TOXIC Edition is based on the latest HD 7970 GHz Edition GPU from AMD, together with a host of industry first and exclusive features to deliver maximum performance. Its unique 6GB frame buffer is a World first for a consumer graphics card and makes the TOXIC Edition ideally suited to multi-screen gaming as well as providing the extra memory required for demanding professional applications such as content creation, video editing or rendering.
Performance is also World leading. By default, the HD 7970 6GB TOXIC Edition runs at 1050 MHz and dynamic boosts to 1100 MHz on the engine with the memory clock at 6000 MHz effective. By pressing the new SAPPHIRE exclusive Lethal Boost Button, the beast is unleashed, boosting the core clock speed to 1100 MHz with dynamic boost to an industry first of 1200 MHz on the engine while the memory is further overclocked to 6400 MHz Effective. The fan profile and PowerTune limit is also changed to performance settings. In addition, users will be able to individually tune the card with SAPPHIRE TriXX, the company’s free to download software tool that allows key parameters to be adjusted for maximum performance.
Features:-
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1050MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 6GB GDDR5
- Memory Width / Speed: 384 bit / 5800MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 2yr Warranty
- AMD 3 for FREE Promotion including Dirt 3 Showdown, Nexuiz, Deus Ex Games (Subject to availability)
Only £499.99 inc VAT.
ORDER NOW
Features:-
- 2yr Warranty
ORDER NOW
