But they come with MSI Afterburner so overclocking them isnt really a problem. Unless you didnt like overclocking that is.
doh! /facepalm moment =x
Som pppl like my frens frens said that 6 core might be renderin and encoding Prove me wrong plsss and goota check balance by today bfore i oreer parts
correct, rendering and encoding can be multithreaded, so more cores = better
but for gaming, intel is better than amd.
oh you're talking about the fx6100?
no the fx6100 is total lousy in everything compared to a 3570k
have a look at this review:
http://forums.overclockers.co.uk/showthread.php?t=18374859
and this is an overclocked fx6100 vs a 2500k that is not overclocked
and the 2500k is 5-10% slower than the 3570k
So u are implying that I5 will out par it ?....well I might be. Buyin all da parts today so wanted to knw more regarding this matter ...also doesn't Intel provide their. Own heatsink for processor? if not when I get my after heatsink do I have to buy thermal paste seperately? Sowwie for many questions -.-
Yes, a 3570k will outperform a 6100 in all areas, AMD BD basically sucks compared to SB/IB. If you buy a retail CPU, it will come with a heatsink with pre-applied thermal paste. If you buy an OEM CPU, it will just come with the CPU and nothing else. If you are going to be overclocking, I would get an aftermarket heatsink- even a cheap one like mine will be better than the stock one. They come with their own thermal paste (I don't know of any that don't)- though you have to apply it yourself (at least you do normally).
Now my fnre is rlly sayin buy fx6100 andn conving why its effective its price and performance..ohh man i am jus gettin mind fcked with these 2 cpus...
no case no hard drive?
Edited and updated...
your friend is just jealous you are getting a better computer
watch these videos
I would suggest replacing the wireless adapter with this USB one: http://www.overclockers.co.uk/showproduct.php?prodid=NW-023-TP&groupid=46&catid=1600&subcat=
It's USB but I'm actually finding this one more reliable and faster than PCI/PCI-E ones.
FX8 vs i5: http://www.anandtech.com/bench/Product/434?vs=288
It doesn't have the FX6 benchmarked, and the i5 is 100mhz slower than the 3570K, but it still beats the FX8 in gaming. This is thanks to the higher IPC (Instructions per clock).
That USB one can also be moved around since it's connected by cable, so it can avoid any inteference the PC might cause. Can also allow you to move the adapter to somewhere with a stronger signal as well, meaning it can avoid those annoying thick walls that might dampen the signal.
