- 29 Aug 2010
- Cornwall
I know this will likely start an argument but that's not my intention.
The title says it all really.
I'm thinking of watercooling my PC (again, sort of, I've watercooled before, but not this pc). If I'm going to watercool I'm not sure I want to watercool my current 2GB 670s (see sig). I'd like to get into triple monitor gaming since I've bought 3 of the 120Hz Samsung monitors (S23A700Ds I think).
I know there's also a lot of discussions about if you need more than 2GB VRAM, but I'm thinking for future proof reasons it might be better (and if I'm watercooling I'm not going to want to have to replace them and the blocks any sooner than I have to). Also, part of the reason I'm watercooling is so that I could go 3-way SLI/Crossfire.
So what is my best option out of 4GB 670s and 3GB 7970s? My current intent would be to get 3 of either card.
I generally lean toward Nvidia cards, probably mostly due to familiarity with the cards and their drivers. There's also the PhysX thing, not that it's widely used, but nice for those occasions when it is.
Still, if the 7970s are clearly better (I think they are cheaper) then I'd be silly not to consider them.
Also, what does annoy me with my Nvidia set up is that if I want to use SLI over multiple screens I have limited options. I can use 2 screens and game on one and have my desktop on the other or I can game on all 3, which doesn't work so well on some games that don't support 3 screens (or ones that I just prefer on 1 screen). Switching between the 2 is a really pain too.
Is the situation the same with AMD cards?
Also, as well as deciding between the 670s and 7970s, which make and model would you recommend for each card? Is it worth going for a OC version of either card? Would there be any difference between a 4GB 670s on a full length (680?) PCB or a short (670?) PCB?
Thanks.
Thanks.
