***The Official Samsung Galaxy S III Android Development Thread***
Using the latest nightly of CM9 and everything seems well. They released RC2 a few days ago I think.
Haven't tried CM10 yet.
They couldn't be simpler :p Just do a full wipe like you would usually, flash the zip and flash the gapps zip.
Done :)
Preview 6 of CM10 is out:
Preview #6 uploaded
- updated proprietary files
- applied samsung opensource kernel update 2+3
- switched to opensource libsecril-client
- updated camera firmwares
Preview #6 uploaded
Now this seems to be a usable build as Phone Audio is now working. Camera still has issues though.
So far its a keeper :)
Did anyone encounter the problem with CM9 where the other person can't hear you in calls? Is it radio related?
Could someone suggest a kernel with NTFS support for SD cards?
I tried Siyah which added a ntfs folder next to sdcard and the external SD card folder, but it wouldnt recognise the file format.
*I should add that I want it so that I can record videos over 4Gb. Apps that enable NTFS mounting allow recording to the SD card, but it still stops at 4Gb :(
Hopefully this helps people asking how to install JB Domination and getting errors in the main S3 thread.
JB DOMINATION v1.4
http://forum.xda-developers.com/showthread.php?t=1730397
Download links
https://sites.google.com/site/vertumusworld/downloads/Themes/Ice-Cream-Sandwich-Domination
Wanamlite
http://wanamlite.com/forums/showthread.php?tid=11293 4.0
http://wanamlite.com/forums/showthread.php?tid=11576 4.1
Installing.
Ignore everything else, people on XDA like to talk a lot of complex stuff even though it's not needed :p
1: Flash Wanamlite 4.0/4.1
2: Flash Stock toggles (linked in Wanam thread)
3: Flash JB Domination 1.3.5 or whatever the latest is to get stock JB look and feel
4: Flash the JB Domination addon, 15 toggles (linked in JB Domination thread, 3rd post IIRC)
Took a while to find this thread.
JB DOMINATION v1.4
Download links
Wanamlite
Installing.
Thanks Cyclone for the post, just a few things i wanted to ask. Before flashing to a new custom rom such as Wanam, i should do a backup in Titanium right?? if i dont i guess ill lose all my settings and info when i flash a new ROM??.
Other thing is that i have a few hacks installed on my S3 at the moment, again when i flash to a new ROM, i will lose those right??.
I am rooted at the moment, was going to wait for the official JB rom to hit but seems like its going to be a little while from what im reading in the main S3 thread. So am tempted to flash to the Wanam JB rom that you have listed above.
If you can answer my q's then id be eternally grateful :).
Im not the best person to ask but here goes :)
Titanium will backup apps and their settings but not the rom. Titanium can also extract settings from a backup. You have root already, then boot into recovery and do a backup. If you have cwm (clockworkmod) then this will do it for you. If a flash goes wrong then you can reinstall this as if nothing has happened.
Im fairly sure ur hacks will go when you've installed a new rom, as you are doing a wipe.
Someone will probably correct me, but when reinstalling apps onto a different rom its best to just do the settings rather than both.
Assuming you do a full wipe when you flash the new rom, you'll lose all your apps, settings and mods.
Thanks Cyclone, i have CWM on my S3 as well so what your saying is that do the backup through CWM rather than titanium??.
Not worried about hacks as i have them on my ext sd card so could always flash them back once ive flashed.
