Hi,
I have recently upgraded from a XFX Radeon HD 6870 to KFA 2 GTX 670. The old card had a 6+6 pin connector. The new card requires a 6+8 pin connector. As of now I am powering the card by using the molex connectors that came with the card. Is there a way that I can power the card using a connector directly from the PSU (Ezcool Infinity 80+) ? The PSU has a 8 pin slot for using a connector, can I get a connector (8 pin) which will go straight to the graphics card. Also as per the KFA2 manual, even the 6 pin connector that goes into the 670 has only 5 pins (the top middle pin is not there) as opposed to the 6 pin that i was using for 6870. So i am not sure if I can use the 6 pin connector that i was using for the 6870.
Thanks for any help.
