Overclockers UK going to stock Corsair Air Series fans??
I have these fans, to be honest they are pretty damn good. Only problem I have with them is they whine quite a lot if you have any restriction on the intake. To make mine silent I would need to cut a clean hole infront of them. Also you have to be VERY careful with the rubber corners when screwing into them. It's just a piece of rubber with a plastic core for the metal fan screws. 1 side of mine completely destroyed, still works and can RMA to corsair np.
Hand held the fans are completely silent to my ears, even at 1650RPM. Move a lot of air too.
Welcome, if you get them make sure to have a fan controller if it's the performance ones if you want to turn em down. Also be so careful and hold the rubber corners still when you install and won't have problems. They look so good, very stylish but simple.
Also bought some of these 140mm
And I think they are quite poor. I bought the silent edition and they are far far from silent. You can hear the airflow a lot, and they seem to have a constant buzz coming from them.
I have had to fit 2 sets of extra resistors to them to make them quiet air flow wise, and the buzz still remains.
Overall I would say look elsewhere. Unless i have a dodgy set of them.
Another review for them;
Hes sponsored by corsair though... so he might be exaggerating. :p
I always watch his reviews....
The AF 140's are a bit noiser. I would be mainly using the SP fans, the quiet series. I will also have a couple of AF ones.
All will be on a fan controller/voltage reducer.
Curious to see how these are myself now.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-006-CS&groupid=701&catid=2331&subcat=1816
Why are my screenshots always fuzzy. -__-
