Mmmmm onion rings
Don't start me off as I've just had breakfast.
Mmmmm onion rings
[FnG]magnolia;22432847 said:It was a light-hearted observation, nothing more.
BRO FIVE!
e : we're only bro-fiving after you wash your damn hands.
I wouldn't know, I think cooking is pouring hot water in to a pot noodle.
I don't know but those things are the bane of my life. Every time I come back from uni and cook for my family I bring 2 portable propane camping stoves, for the life of me I cannot cook on an electric hob, it's either hot as hell or cold as ice, or when you want to turn it down it takes 5 minutes to do that and knackers up your dish.
And thats if it ever heats up, had a pan on the hob full whack here before, 10 minutes later it wasn't anywhere near hot enough to cook a steak.
Rant over
Rant over
Rant over
Obviously something wrong with it.
We'd have 32 cookers on test in a lab (16 gas, 16 electric) and you would have to get to the electric hobs faster so the water didn't boil over.
Electric is way quicker and this was in 100% of cases over 27 years I was doing it.
The only time it wasn't faster is if the element was buggered.
....I've touched a few million in my lifetime...
At the end of the element are two tabs with the wires on so if you touch them you will get electrocuted and I have done several times and been thrown across a test crib.
I'm guessing because the electric heating element it larger covering more surface area of a pan than say the flame from a gas ring. Whilst the flame burns hotter/quicker the electric ring is putting out more heat in total.How does that work? Serious question.
Gas is instant heat, there is no 'heating up' delay like you get with electric. Is it because the hobs can ultimately reach a higher temperature when they do finally get there?
I used to have electric hobs at home, but now have gas and in my experience the gas is quicker.
path of least resistance is the way that electricity flows.
When you say "we" do you mean you and Jimmy Hendrix?
Delay of a couple of seconds.
We used to play games to see how long you could leave your hand on an electric hob to see how manly we were.
Using temperature readers the electric would reach higher temps.
All those cookers are linked to a program called Picolog which would measure temperatures depending where we put the sensors.
Why do nearly all professional kitchens use gas then? Is it cheaper?
