Hired one out from the airport as an alternative to a Focus or similar as it would be a rival to our Hyundai and similar to the Fiat 500 we had in the UK.
It looks pretty good, but they seem very common on the road.
Engine goes well, the one I have is the 1.6, revs sweetly, gearbox isn't too bad, but could do with a 6th gear, revs are around 3500 at motorway speeds which makes it quite loud inside the cabin.
Handling is very good, loads of grip and excellent feedback through the wheel.
Boot space is good for a small car, took both cases and a small carry on case, the parcel shelf didn't sit perfectly afterwards, but they went in without the seats going down.
I can't believe how poor the interior is, the seat is impossible to get comfortable, with limited adjustment in almost every direction. It is all made from fairly low grade plastics and pretty scratchy and shiny. The armrest obstructs the handbrake. The steering wheel doesn't adjust for reach, meaning I have to drive hunched forwards as I need to put the seat back quite far as the pedals are close to the wheel. The glovebox is almost non existant and no storage space under the armrest, limited in the doors. There are no cupholders.
The radio seems like it was just lifted from a 90's Citroen and is way too low down, where is the ipod input? There is an Aux in, but this is in between the front seats, with the awkward armrest and then the handbrake in the way. No steering wheel mounted phone controls, I don't even know if it does bluetooth to your mobile. This seems totally stupid when the car has cruise/digital aircon/folding electric mirrors, might just be a hire car special?
What is wrong with knobs to turn for the aircon/heater. You have to press a button to adjust which vents are operating. Of course you always press the button once more than you intended to, which then means you have to press it 5 more times to cycle back through to get onto the setting you originally wanted. Yet for the speed of the fans, this has a button for up and a button for down!
