Boot device and windows
21 Dec 2011
Hi guys
Not sure if this problem could possibly be hardware related and I'll tell you why. Built my pc yesterday and it fires up first time no problems. I select preferred boot device to the cd drive and input the windows disk but it doesn't boot from the disk. I also tried it using my USB external hd and also my USB pen drive but it won't start windows install.
I get the message to input a proper media device or cd and press any key to continue which I do, but again nothing.
...I select preferred boot device to the cd drive and input the windows disk but it doesn't boot from the disk...
If you go into BIOS-> Boot Devices, can you actually see the name of the CD drive ? And when you put the disc in it, do you see the lights working, as in trying to read the disc ?
Yes and I can also hear it spooling up which is why I'm confused as to why it's not working really. Hope it hasn't been damaged in any way :(
No, another bootable OS disc. Did you look in the BIOS to see if the CD drive is recognised ?
Edit: You could always try and boot from that disc on another machine to see if the disc is at fault !
Ok got a hold of my Dad's disk and that worked so seems it's my disc unfortunately.
Another small problem, when installing windows I could see my main HD listed, but now that windows is installed I can't see it in My Computer.
I've checked and double checked all cables, any ideas?
click start/right click my computer/storage/disk management
if the hdd shows in there right click it and mark as active
it should show up then
It's the 1TB one.
